Message Waiting Lamp - CISCO 7960
Discussion in '3CX Phone System - General' started by Anonymous, May 14, 2007.
  1. Anonymous
    Anonymous Guest
    Hello Everyone,
    Does anyone know how to get the message waiting lamp functional with the CISCO series IP phones? I've successfully configured a 7960 to register with 3CX but cannot seem to get the message light to work.
    Thanks in advance.
    Brian
    http://www.jaydien.com
  2. TwigsUSAN
    Jan 31, 2007
    45
    Right now the Message Lamp indicator doesn't work with any phone with 3CX at the moment. Something they are currently working on.
  3. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,309
    Roger that. We have experimental support of MWI, but it has to be tested more.
  4. Anonymous
    Anonymous Guest
    Can I help test it? :D
  5. archie
    3CX Support
    Aug 18, 2006
    1,309
    Yes, as soon as it appears in new release :)
  6. Anonymous
    Anonymous Guest
    What is the timeframe for the new release? Thanks.
    Brian
  7. riceboi
    Apr 11, 2007
    17
    I am interested in this as well as this feature is quite problematic with cisco 7970s.
    do you have a time frame on your next release as mentioned above ?[/url]
  8. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,873
    171
    The timeframe for the release is first half of June
  9. smares
    Dec 24, 2007
    Has anyone been able to get the CISCO 7960 Series phones MWI light to work with 3CX yet? I was wondering if there had been any progress? Thanks!
  10. ITWorks
    ITWorks New Member
    Apr 7, 2007
    121
    I do not have any 7960 phones to test with but the MWI is working with Cisco 7941 and 7961 phones and the latest version of 3CX!
  11. respecte
    Feb 20, 2008
    10
    Does anyone have a complete process to convert a sccp to sip on Cisco 7961?. The current load file is sccp41.8-2-1s. Thanks you!
  12. Wardy
    Wardy New Member
    Sep 18, 2007
    110
    Does the 7961 use the same firmware as the 7960 if so I can let you have a copy of my config
    Stephen
  13. smares
    Dec 24, 2007
    I've got the 7961's running with the latest version of 3CX and still no message waiting light. What SIP version are you using on the phones?
  14. ITWorks
    ITWorks New Member
    Apr 7, 2007
    121
    SIP11.8-3-3SR2S and Enterprise Edition of 3CX
    Mark
  15. ITWorks
    ITWorks New Member
    Apr 7, 2007
    121
    Oops. Above is the firmware we use on the 7906's.
    The firmware we use on the 79x1 series is SIP41.8-3-2S. This version has proper functioning DND and MWI.
  16. sabalsam
    Jan 25, 2008
    I have just upgraded to a paid system. The solution is almost too easy.
    In the SIPDefault.cnf file, you must add the following entry:
    # Dialtone Stutter for MWI
    stutter_msg_waiting: 1 ; 0-Disabled (default), 1-Enabled
    This not only enables a stutter dialtone, but also lights the message waiting indicator light!
    It also lights the MWI regardless of what line position has the message. The cisco system will only light the message light if the message is waiting on the first line.
    Seth Balsam
    Fort Lauderdale
  17. alex22alex
    Jun 11, 2008
    38
    Sorry just to clarify does this work with the 3cx paid version or another paid system ?
    Cheers Alex
  18. CentrexJ
    CentrexJ Member
    May 5, 2009
    363
    41
    Message Waiting Indicator is a feature of the Paid 3CX versions and not available in the Free version.
  19. alex22alex
    Jun 11, 2008
    38
    Ok. Thanks for the clarification.
    Alex
