Method Not Allowed
Discussion in 'Windows' started by jgemio, Oct 13, 2011.
  1. jgemio
    Oct 13, 2011
    I have installed 3CXPHONE ver. 5.0.14900 over Windows XP. My Pbx is running Asterisk 1.4.22. All is working perfect but in the Asterisk Console appear a recurrent error
    Got SIP response 405 "Method Not Allowed" back from 172.23.177.125
    I attach a sip debbug. Does have anybody the same problem?
    Thanks and Regards
    <--- SIP read from 172.23.177.125:4730 --->
    SIP/2.0 405 Method Not Allowed
    Via: SIP/2.0/UDP 172.23.187.229:5060;branch=z9hG4bK463d9598;rport=5060
    To: <sip:1001@172.23.177.125:4730;rinstance=9baa4052e73d50c9>;tag=4d374c31
    From: "Unknown"<sip:Unknown@172.23.187.229>;tag=as746a4792
    Call-ID: 3b323df43bd9eb7e3aaf4f88493960f6@172.23.187.229
    CSeq: 102 NOTIFY
    Content-Length: 0
    --- (7 headers 0 lines) ---
    -- Got SIP response 405 "Method Not Allowed" back from 172.23.177.125
    Really destroying SIP dialog '3b323df43bd9eb7e3aaf4f88493960f6@172.23.187.229' Method: NOTIFY
    Reliably Transmitting (no NAT) to 172.20.24.131:5060:
    OPTIONS sip:172.20.24.131 SIP/2.0
    Via: SIP/2.0/UDP 172.23.187.229:5060;branch=z9hG4bK7324ab89;rport
    From: "Unknown" <sip:Unknown@172.23.187.229>;tag=as6d80049c
    To: <sip:172.20.24.131>
    Contact: <sip:Unknown@172.23.187.229>
    Call-ID: 3c624d474fbcc0dc7d8aa47643b1dd14@172.23.187.229
    CSeq: 102 OPTIONS
    User-Agent: Asterisk PBX
    Max-Forwards: 70
    Date: Thu, 13 Oct 2011 08:34:40 GMT
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
    Supported: replaces
    Content-Length: 0
    11,116
    329
    It would appear to be a setting in your PBX.
    Response Code 405=
    The method specified in the Request-Line is understood, but not
    allowed for the address identified by the Request-URI.
    The response MUST include an Allow header field containing a list of
    valid methods for the indicated address.
  3. opsimm
    Dec 9, 2012
    Just remove stun server stun.3cx.com from advanced settings
    voala
