Mexico SIP Provider
Discussion in '3CX Phone System - General' started by Brett Coleman, Dec 5, 2017.
  1. Brett Coleman
    Jun 20, 2017
    27
    Any recommendations for a SIP phone provider in Mexico?
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,599
    209
    Worth contacting some of the world-wide providers and seeing if any of them can provide you DDI's for your country of choice: https://www.3cx.com/partners/sip-trunks/worldwide/
    If not you will need to simply look for an un-supported Mexican SIP trunking provider and set them up as a "Generic" SIP trunk in the 3CX interface.
    Not something I would normally encourage but if there are not other options it would be the only thing you could do.
  3. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    692
    216
    Check didlogic, you can have national and Mexico city numbers.
  4. eddv123
    Aug 15, 2017
    1,599
    209
