MIC volume low on Samsung Galaxy S-II
Discussion in 'Android' started by eagle2, Oct 3, 2011.
  1. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Users complain the MIC volume is very low (and non-adjustable) using 3CX Phone (1.3.2 w/ tunnel) on Samsung Galaxy S-II phones. Any ideas ?
    Regards,Orlin.
  2. barter007
    Nov 11, 2011
    I also have the low volume mic issue with my samsung galaxy s2.
    Here is what i have found from :
    forum.xda-developers.com/showthread.php?t=1127103&page=4
    It would be nice that 3cx developpers fix this issue with our Samsung S2.
    FranK
  3. barter007
    Nov 11, 2011
    I did some tests and I confirm that the MIC on the upper side of the Samsung Galaxy S2 is the enabled one when using the 3CX Phone applicaton for Android. This is why you need the Mic Gain set at maximum value (8), as a workaround, when speaking toward the bottom mic of the phone.
    The tests were made on the 1.3.4 version of the application.
    Please have this issue fixed as soon as possible.
    Thank You.
    FranK.
