microsoft crm 4.0 integration
Discussion in '3CX Phone System - General' started by dshulmistra, Sep 22, 2008.
  1. dshulmistra
    Aug 26, 2008
    7
    is there a solution to integrate 3cx into the microsoft crm 4.0?
    thanks,
    dale
  2. dshulmistra
    Aug 26, 2008
    7
    we're using linksys spa942 phones.
  3. dshulmistra
    Aug 26, 2008
    7
    haha. :oops:
    outgoing phone dial function, and ability to log the call as an activity for the contact (or lead).
    thx,
    dale
  4. surfie
    May 26, 2007
    31
    Check this link: http://www.3cx.com/forums/3cx-microsoft-crm-6987.html#p35115
    it's for the crm 3.0 version, but I think you will need the payed version to use the web services (http API)
