Microsoft Dynamics 365 Integration Language
Discussion in 'Ideas' started by stefanprasch, Jul 10, 2017.
  1. stefanprasch
    Aug 28, 2015
    11
    Is there an option to change the language in german, or in an other languages?
    Thanks!
