Solved Microsoft Dynamics 365 Integration missing from 3cx management console
Discussion in '3CX Phone System - General' started by Michelle Dinh, Dec 8, 2017.
  1. Michelle Dinh
    Dec 5, 2017
    10
    Trying to integrate dynamics 365 to 3CX, but I don't see it as an option under the settings
    Settings --> CRM Integration
    I only see the following:
    - connectWise
    - Nutshell
    - Zendesk
    - Bitrix
    - Freshdesk
    - Salesforce
    Is the integration compatible with Pro V15.5? Please help!
  2. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    220
    It is available for client side installation, not server side:
    amarbl likes this.
  3. Michelle Dinh
    Dec 5, 2017
    10
    Thank you for your help!
