Microsoft FAX for Outbound.
Discussion in '3CX Phone System - General' started by chrisneal, Feb 8, 2011.
  1. chrisneal
    Nov 20, 2008
    27
    After installation of v9 of 3CX Phone system.. Where is the install to add the 3CX as Devices to the Microsoft FAX services. Can't find that link anymore?
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    3CX have discontinued the Fax Server and is no longer available
  3. riessfr
    Feb 15, 2011
    is there any other working solution planed or already existing?
    thanks for your info.
  4. custodian
    Dec 17, 2010
    22
    I'm also curious to find a solution to use Microsoft Fax to send Faxes out over T.38. If anyone has any tips, they'd be most appreciated.
  5. riessfr
    Feb 15, 2011
    i found a solution, which is working (http://www.t38faxvoip.com and http://www.sipcall.at for t.38). but not for sending PDF. when i use windows fax and scan there ist no problem. when i use Outlook 2003, exchange 2007 and faxmailtransport, then outlook sends a message, that the attachment is not correct and cannot be sent.
    thanks for your ideas.
  6. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Relay Fax is the best. Contact me for information and for a 30 day trial.
