MicrosoftDynamicsCRM doesn't load on domain joined pc
Discussion in 'CRM / Helpdesk / App Integration' started by amaurib12, Feb 2, 2018.
  1. amaurib12
    Feb 2, 2018
    I have a Win10 computer joined to a domain where the 3CX phone client is unable to load active integrations and only the "General" script is loaded.
    If I right click and run the phone client as an admin, the MicrosoftDynamicsCRM loads just fine..
    what permissions do the 3cx phone client needs to load the integrations?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,361
    109
    Hello @amaurib12,
    3CXPhone needs to write files to the following folder:
    C:\ProgramData\3CXPhone for Windows\PhoneApp
    Kind regards.
    Ernesto.
  3. amaurib12
    Feb 2, 2018
    Hello Ernesto,
    I have configured the folder you mention with full permissions for all domain users. Still same problem. it doesn't show the MicrosoftDynamicsCRM script.. only General.
    Here is clean log of the phone client..
    https://pastebin.com/embed_js/2R9fT1vX
  4. edossantos
    Jun 27, 2007
    1,361
    109
    Did you assign the integration package to the extension? If you did, try manuallly deploying the integration to the extension, as follows:
    1) From the server, copy the integration ZIP file from "C:\ProgramData\3CX\Instance1\Data\Http\Interface\MyPhone\Integration\MicrosoftDynamicsCRM.zip" in Windows or "/var/lib/3cxpbx/Instance1/Data/Http/Interface/MyPhone/Integration/MicrosoftDynamicsCRM.zip" in Linux, to the 3CXPhone machine
    2) Unzip the file to the folder "C:\ProgramData\3CXPhone for Windows\PhoneApp\DotNetScripts". If folder DotNetScripts doesn't exist, create it.
    3) Copy the file "C:\ProgramData\3CXPhone for Windows\PhoneApp\DotNetScripts\MicrosoftDynamicsCRM\3CXCRM.ini" to the folder "%AppData%\3CXPhone for Windows".
    4) Configure the plugin as explained in the Dynamics CRM guide.
    Kind regards.
    mohammad01 likes this.
  5. amaurib12
    Feb 2, 2018
    Hello Ernesto,
    Yes the integration package was already assigned to the extension. Even the integration was copied to the computer.
    One thing I noticed is that the 3CXCRM.ini file wasn't getting copied to the profile without administrative privileges. Everything else was in place.
    After copying 3CXCRM.ini to the non admin user "%AppData%\3CXPhone for Windows" , the integration does appear on the phone client..
    Right now im on a test lab but have plans on deploying this to dozens of computers.. what do you think is causing this file not being copied to other user profiles? isn't this part of the extension deployment process?
    #5 amaurib12, Feb 2, 2018
  6. edossantos
    Jun 27, 2007
    1,361
    109
    Yes, that's part of the deployment process. If that file is not being copied, then there might be some permissions issue preventing that to happen...
