jms
- Joined
- May 23, 2011
- Messages
- 56
- Reaction score
- 0
The v14->15 upgrade migrates the Patton Smartnode 4120 as two devices.
After migration if you add an inbound rule it doesn't seem to work. I updated the Patton to the latest firmware, updated 3CX to the latest Patton templates and created a new gateway, and it worked well. It makes it as one object and everything works after you've re-entered all the DIDs. (It would be nice if you could enter a range of numbers).
I deleted the first of the old Smartnode objects and the second one disappeared at the same time.
Now there is a red bang on the dashboard called "System Extensions". If I click it there is an unregistered extension on the next page called "90002", which was the ID of the second channel on the old Patton object.
I've migrated three branches that use 4120s, this happened on two of them.
How can I get rid of the non-existent System extension?
