Migrating Recordings from Asterisk/FreePBX to 3CX
Discussion in '3CX Phone System - General' started by Roeller, Mar 3, 2016.
  1. Roeller
    Mar 3, 2016
    7
    I am testing a migration path from migrating a Asterisk/FreePBX server to a 3CX Server.
    3CX stores recordings in the default directory: C:\ProgramData\3CX\Instance1\Data\Recordings\
    It uses the name format: DisplayName_Ext_DialedNum_YearMonthDayHourMinuteSecond.wav
    Can I just put fiels in this directory as long as it is according to the above name format?
    I tried and restarted the server,. but nothing is seen on the recording page. Should I also edit/add records to a database somewhere?
    As soon as I have a working migration path/scenario, I will write about it!
    Kind regards,
    Roel Broersma
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,252
    63
    I just tried this and it seems to work, manually placing .wav files in a directory.
    What I did was in folder C:\ProgramData\3CX\Instance1\Data\Recordings\, I created subfolders for extensions, so all the recordings for ext 101 would be in C:\ProgramData\3CX\Instance1\Data\Recordings\101\, and if in this folder you put a .wav file in format:
    [DisplayName]_CallerID-DialedNum_YearMonthDayHourMinuteSecond.wav
    It showed up, no restart required, just click away from "Recordings" and back again.
