Migration Issue
Discussion in '3CX Phone System - General' started by Flash99, Nov 29, 2017.
  1. Flash99
    Aug 3, 2017
    98
    8
    We moved 3CX v15 from old server to a new one.
    On the old server 3CX was install on C: drive
    In the new server the install is on D: to help us separate 3CX from OS
    Everything works ok after the migration, but I noticed on a dashboard that a free space that was reported was C: drive free space.
    I checked Parameter Settings and I noticed that all locations were still C:\....
    I double checked and 3CX is install on D:\
    So I'm not really sure how 3Cx actually works while parameters point to a wrong place
    I tried to change the parameters manually, but after restart 3CXQueueManager01 would not start.
    Any idea what should I do ? What would be the correct way to make 3CX work from D: drive ?
  2. StefanW
    Jun 2, 2009
    1,230
    95
    even installing the main dll and exe on D the main part of your config is part of the programfiles dir and with this within C. We are aware for recordings that we can not monitor currently any other drive then C but will keep this in mind for the future...
