Solved Mikrotik SIP ALG
Discussion in '3CX Phone System - General' started by davidm85, Jan 30, 2018.
  1. davidm85
    Jan 15, 2018
    13
    I recently installed a new router a Mikrotik Hex.
    When I first ran the 'firewall checker' sip alg was not detected.
    But now it states 'failed', although the sip alg is deactivated on the router.
    What could cause this problem?
    thanks
  2. mariosM_3CX
    mariosM_3CX Support Team
    Nov 1, 2017
    406
    38
  3. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,311
    249
    I had intermittent test issues with the Firewall Tester using a Mikrotik. My system works just fine. I do see they do not have an outbound SNAT on the Mikrotik instructions but I have found my system to be more stable with it.
  4. davidm85
    Jan 15, 2018
    13
    thx for the replies.
    I've checked all the setting from the 3CX doc but everything seems fine.
    The error about the sip alg test keeps comming up.
    the strange part is that with the first run, everything was ok
  5. Brian Cross
    Brian Cross New Member
    Jul 26, 2017
    109
    27
  6. davidm85
    Jan 15, 2018
    13
    thx @Brian Cross but when I run the tool, I get an access denied message (run the tool as administrator)
  7. Brian Cross
    Jul 26, 2017
    109
    27
    Hmm local firewall on or something?
  8. davidm85
    Jan 15, 2018
    13
    the windows firewall is off,
    and the mikrotek router has factory settings, with just the 3CX settings
  9. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,335
    73
    I
    T could be that it can't bind to port 5060 because something else is using it. If you ran this on the 3CX Server, for sure 5060 is being used by 3CX. Stop all 3CX services and try running this tool again (as admin), maybe this helps...
  10. davidm85
    Jan 15, 2018
    13
    this was indeed the problem, when i shutdown the services and disable the 5060 udp and tcp rule, the test works.
    I also had a conversation with one of your colleagues, and the sip alg test works in 3CX when i disable the 5060 - udp rule in the router. Strange behavior, because all settings are taken from the 3CX mikrotik guide
  11. Brian Cross
    Jul 26, 2017
    109
    27
    Makes sense I usually run it on a workstation on the network not on off the 3cx server. So what was the verdict SIP ALG off?
  12. davidm85
    Jan 15, 2018
    13
    With the help of the mikrotik forum I managed to solve the issue, I had to add a setting to the router firewall settings for 3CX protocols.
    I had to set incoming interface= wan interface.
  13. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,016
    420
    Glad to see the issue has been resolved and thank you for updating the thread with your solution
