Minor bug: directory listing xml files Linux
Discussion in '3CX Phone System - General' started by AlnHky, Feb 17, 2017.
  1. AlnHky
    Feb 10, 2017
    Two things I've noticed with my new installation of 3CX (Linux ISO).
    When you add users through the web interface the created xml files - both 000000000000-directory.xml and 3CXPhone-directory.xml files have the individual's first name in the <ln> or <LastName> fields.
    Secondly, when the <MAC>-directory.xml file gets created in the provisioning directory it is upper case (MAC) and the phone log shows it is looking for <lowercase MAC>-directory.xml. In the provisioning directory I moved the uppercase MAC directory file to lowercase. After telling the phone to re-provision from the web page the phone still complained in finding the file.
    #1 AlnHky, Feb 17, 2017
  2. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    We will check this - thanks for the feedback
