Minutes to MBs
Discussion in '3CX Phone System - General' started by alonchu, Jul 18, 2008.
  1. alonchu
    Jul 18, 2008
    21
    Hey Everyone,
    I want to install a 3cx server at my office.
    I would like to know if anyone has checked to see, the ratio between minutes and MBs.
    EG If I talk 3000 Min. on my cell phone how many MBs will it use via a UTMS network.
    Thanks a lot!!!
    Alon.
  2. alonchu
    Jul 18, 2008
    21
    My carrier does not have an unlimited plan.
    However they do have a 5gb plan, but it's abit pricey.
    I am only asking because I am tring to figure out if it makes sence or not.
  3. alonchu
    Jul 18, 2008
    21
    Will Do!
    I will update the feed when I do, so that everyone will know the answer.
    Alon
  4. justin
    Feb 20, 2008
    79
    Well the easiest way is just to calculate it manually. With G711 the data rate is about 9kbs, but we'll say 10 for simplicity and to be on the safe side :)
    1024kb (1mb) / 10kbs = 102.4seconds
    102.4seconds / 60 = 1.7minutes
    So 1 mb is approx 1.7 minutes of talking on the G711 codec
  5. BJReplay
    BJReplay New Member
    Oct 31, 2007
    133
    Based on Justin's figures, 1GB is around 1700 minutes, and 5GB is a lot of minutes.
    Remember, though, that you'll be paying for data for calls you receive as well as those you make, when comparing to a capped mobile plan.
  6. ecwilson
    ecwilson New Member
    Jul 12, 2007
    118
    Also here is a link where you can put in your monthly minutes & it
    will tell you your Mbps used per month. Hope this helps
    http://www.thevpf.com/solution/mpm
    ecwilson
