misconfiguration outbound voip/sip axtel
Discussion in '3CX Phone System - General' started by clonick, Nov 27, 2012.
  1. clonick
    Apr 19, 2012
    26
    Hi to all
    2 weeks ago I finisedh installed correcly the test pbx server, i'm using axtel provider for inbound and outbound, but some days ago i was not able to make calls from extensions, only i can recibe (inbound calls)
    when i call a number, the 3cx shows than the extension is trying to make call, (calling status) but in the trunk status it never shows calling or something, also in a polycom phone i recive the error 408 and in grand stream i recibe 480 in the lcd screen.
    so in the next log the info is:
    89900000 = the number than I tried to call from the extension
    192.168.0.100 = local ip of the server
    10003815430ip = auth id of my voip provider
    mty13.axtel.net = host and out proxy of my voip provider
    NOTE: IN THE NEXT PARAGRAPH, AT THIRD LINE IT SAYS \\@mty1.axtel.// were it was exact copy/paste from log, but the server must be mty13.axtel.... as it shows in the other lines.... this is common? why ? or could be part of the problem?
    Code:
    08:13:34.887  [CM503020]: Normal call termination. Reason: No answer
    08:13:34.887  [CM503016]: Call(16): Attempt to reach <sip:89900000@192.168.0.100;user=phone> failed. Reason: No Answer
    08:13:34.886  [CM503003]: Call(16): Call to sip:89900000@mty1.axtel.net:5060 has failed; Cause: 408 Request Timeout; from IP:207.***.***.154:5060
    08:13:14.691  [CM503025]: Call(16): Calling VoIPline:89900000@(Ln.10005@AxtelHQ)@[Dev:sip:10003815430ip@mty13.axtel.net:5060]
    08:13:14.566  [CM503004]: Call(16): Route 1: VoIPline:89900000@(Ln.10008@AxtelHQ)@[Dev:sip:10003815430ip@mty13.axtel.net:5060]
    08:13:14.562  [CM503001]: Call(16): Incoming call from usrext1000 to <sip:89900000@192.168.0.100;user=phone>
    i believe than is a mismatch config of the outbound sip parameters...
    any suggestion ?!?
  2. markshehan
    markshehan New Member
    Nov 14, 2012
    141
    You will need to run a wireshark to see if it is leaving 3cx and if you are getting a response from the provider.
    The error is saying a time out from them. A good place to start is to check firewalls in case something changed. Then call your provider to see if they see your invite coming to them.
  3. sigma1
    sigma1 Active Member
    Nov 20, 2009
    542
    Run firewall checker. It looks like your SIP trunk provider is not able to reach your PBX or is simply ignoring you (dropping packets). Wireshark would help
  4. clonick
    Apr 19, 2012
    26
    ok, i will try wireshark but the firewall checker says all is passed, soo ...
    i thing is a mismatch config of the outboud sip parameters, cuz in the log apparently is sending the lan ip no the public ip....
    thanks
