Missed call from "Ring Group" on Yealink
Discussion in '3CX Phone System - General' started by craigreilly, Mar 3, 2014.
  1. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,586
    309
    Using T38 and T46 - is there a way to make a missed Ring Group call not show as a Missed Call?
  2. sohc
    Apr 22, 2009
    24
    I would love to know how to do this as well. I hope someone can share some light...
  3. leejor
    11,277
    360
    I know that this has come up before, can't remember if there was a solution. It requires that the PBX send Reason: SIP ;cause=200 ;text="Call completed elsewhere" and for the phone to respond appropriately by not displaying a missed call.
  4. craigreilly
    Feb 1, 2012
    3,586
    309
    Before I go do some troubleshooting - does 3cx send this?
    If so - then off to Yealink who doesn't seem to be supporting my T38 phone anymore...
  5. leejor
    11,277
    360
    I do remember some complaints abut that before (perhaps some feature suggestions), I don't remember if a change was implemented in one of the newer versions. I find it is getting harder to do a search, on the 3CX site, and actually find, a topic that you know is somewhere in the Forums. I do see the same thing happening on my Linksys SPA942s.
