Missed Calls Linksys 941
Discussion in '3CX Phone System - General' started by jware, Jul 15, 2009.
  1. jware
    Jul 15, 2009
    We have two same setups with the following problem.
    Phones: Linksys SPA941
    We configured a ring group with several extensions in it and the option: ring all.
    Well this works, but when one extension pick ups the phone the other phones get the message of a missed call.
    This is very annoying, because you cant figure out which calls are really the missed ones.
    Does anyone have a solution?
    Thanx in advance!
  2. voipbaennjer
    Jul 10, 2009
    44
    I've read somewhere in this forum that there is one phone manufacturer whos phones have the ability to recognice that a call has benn answered by another phone of the ringgroup but I can't remember where. Mayby I find it again...
  3. pjr
    pjr New Member
    Oct 5, 2009
    154
