Missed calls to a ring group always listed twice
Discussion in '3CX Phone System - General' started by Severin Meyer, Mar 9, 2018.
Tags:
  1. Severin Meyer
    Jul 29, 2017
    53
    I have a ring group "80" which will ring 4 extensions on the same time.
    The ring group is assigned to a DID, so incoming calls are ringing on all extensions.
    This works as it should.
    But whenever a call is missed, on each client, the missed call is listed twice.
    There is no difference if the ring group "80" is called from outside via DID or is called directly form an internal extension via "80".
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,358
    535
    Hello @Severin Meyer
    Do you have multiple devices on the extensions or are you just using the 3CX client?
  3. Severin Meyer
    Jul 29, 2017
    53
    This is different.
    I have an extension which is used as desktop phone with windows client for cti
    Another extension is just the desktop phone.
    Another is just the Android client.
    The missed call is listed twice on all extensions and also the webclient.
    Only the Desktop Phone Yealink T46s is listing only one entry, I think because of the same timestamp it is filtered internally.
  4. YiannisH_3CX
    May 10, 2016
    7,358
    535
    Please note that this is a known issue and we are currently looking into it but it is affecting only the clients. What IP phones do you have that display the issue?
  5. Severin Meyer
    Jul 29, 2017
    53
    As I wrote, only clients having this problem. No IP-phones.
    I have really searched for this problem, but was not getting any result.
    Is there a separate list of known problems?
  6. mburtscher
    Oct 6, 2017
    11
    We are having that problem with a ring group and an extension that uses both an IP phone and the Android client app.
    Is this issue fixed already or is it still “under development”?
    kyle dee likes this.
