Missed Calls
Discussion in '3CX Phone System - General' started by telefoner, Apr 9, 2015.
  1. telefoner
    Apr 9, 2015
    Is it possible for someone (such as an assistant) who has another person's extension on their phone (their boss) setup via BLF to view the missed calls from that other extension?
    Thanks in advance.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    Unfortunately, not in this scenario.
    The BLF key is merely acting as a status indicator of the extension being monitored. You will need to put the account on the admin's phone so that it also acts as the boss' extension (which will cause it to ring as well), or use the 3CX phone for Windows client, but still set to be the boss' extension.
  3. telefoner
    Apr 9, 2015
    Got it. Thanks for the quick reply.
