Missing Aastra Phone**PENDING CHECK
Discussion in '3CX Phone System - General' started by maddrm, May 31, 2011.
  1. maddrm
    May 31, 2011
    6
    When I am trying to provision a new phone, the in the dropdown for the phone model, the Aastra 6739i is missing. This has happened after the v10 upgrade.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,111
    143
    Re: Missing Aastra Phone
    Yes we removed this support because it was unstable.
    What you can do is the following
    Go to Settings / phone provisioning / templates aastra.ph
    find the part where it says <model>Aastra 6730i</model> etc etc and at the end in the <model> tag add this
    <model>Aastra 6739i</model>
    Save
    Close winforms and start it again
    Provision the phone using this template.
    Let me know how it goes - I am more interested in the stability of this phone because it gave us a lot of problems - however from the feedback I got from aastra it seems that the latest firmware greatly improves the phone - so let me know - i would appreciate first hand customer/user feedback.
  3. maddrm
    May 31, 2011
    6
    I use the 6739i and I love it. The bluetooth is a bit picky with the devices it will or won't pair with. We have one setup with a sidecar and it is working great. Are there any specific problems I should be looking out for?
    PS: the HTML tags did the trick
  4. nb
    nb Support Team
    Jun 7, 2007
    2,111
    143
    I think you have the latest update because the problems when we had tested it were very evident. It was rebooting all the time and crashing leaving of course a lot of stale registrations.
    Use it and send me an update in a week. If it goes well we will retest the phone and eventually might add it as supported.
  5. maddrm
    May 31, 2011
    6
    We have had a great success rate with the Astras 6739i. I am having more issues with the BLF lights on the 6757i. I wish I had gotten the 6739i for the entire office.
