Missing attachment in Welcome Email
Discussion in '3CX Phone System - General' started by datalib, Oct 20, 2016.
  1. datalib
    Aug 7, 2011
    Hi there..
    I have just upgraded from V12 to V15.. very pretty.
    All is going well.. but I cannot seem to get the system to send the welcome email with an attachment, which we need to get the Windows/Android phones working.
    Any suggestions where I could look would be helpful.
    Chris
  2. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    I hit that once.. ended up rebuilding.
  3. 3CXusername
    3CXusername New Member
    Jul 31, 2014
    182
    15
    Not sure if that means smtp is working at all or just the attachment delivery is an issue.
    If attachment issue, double check parameter "ATTACH_3CXCONFIG_WELCOMEEMAIL" is set to 1 (enabled).
