Missing BLF Configuration 3CX Mac Client
Discussion in '3CX Phone System - General' started by Torey Maerz, Dec 5, 2016.
  1. Torey Maerz
    Dec 5, 2016
    Trying to configure the mac client BLF fields and they are missing on the mac client. These docs show it, but the show blf side panel is simply missing from the mac client I'm using. Which is the most recent one.
    http://www.3cx.com/user-manual/installation-mac
    Any ideas?
  2. AH2
    AH2 New Member
    Mar 14, 2017
    112
    5
    I've been looking for BLF on the Mac client, looks like not available, or am I wrong ? didn't want to open a new ticket having this one already.
    Thanks.
  3. pact
    pact New Member
    Dec 16, 2009
    219
    41
    Hi Torey,
    The MacOS Client does not currently support the BLF Sidepanel.
    The picture you are seeing in the docs is not the BLF panel, that is the presence information. (Which will simply show everyone, in extension order, on the system).
    About the best you can do is submit an idea on the Ideas forum: https://www.3cx.com/community/forums/3cx-ideas/
    AH2 likes this.
