Missing: call info, recordings, voicemails
Discussion in 'iOS' started by integrity2, Sep 8, 2013.
  1. integrity2
    Nov 10, 2009
    22
    I'm on 3cx 12 and using the 3cx 12 ios app. If I record a phone call it doesn't show in the recordings of the app - missed, received, all call info is come rely blank - as is voicemails.
    Are there some settings or firewall rules I am missing somewhere?
    Thanks!
  2. integrity2
    Nov 10, 2009
    22
    Edit with required details
    Phone Model: [iPhone]
    Generation: [4s]
    Firmware Version: [6.1.3]
    Jailbreak: [NO]
    Issue Info
    Handset: [Phone]
    Contacts: [Local]
    Connection: [3G and wifi]
    Server: [External and external]
  3. sraoof
    Dec 26, 2012
    im having the same issue. anyone have any info on how to correct this?
  4. StefanW
    Jun 2, 2009
    1,210
    85
    top left "CTI Connection"
    bottom left "SIP Connection"
    u need to have the port 5000 for http and 5001 for https frwd to the pbx.
    however make sure ur https connection is correctly formulated (https://FQDN:5001)
    iOS does not fall back to http when https is not connecting!
    & You must use provisioning (pnp or via e-mail to connect to the cti interface)
  5. integrity2
    Nov 10, 2009
    22
    Ok, if you installed using http option instead of the https option, is that going to cause a problem? Is the ios app still going to use https?
    Is that cti and sip connection in the 3cx extension configuration?
    Thanks for the response!
  6. StefanW
    Jun 2, 2009
    1,210
    85
    no, then the iphone will use the http connection. in case you have installed pbx with https option (and in the config file to the phone we find on ios https and http) we only use on ios http. android and windows behave here different and fall back after a try to https to http...
  7. integrity2
    Nov 10, 2009
    22
    Does it matter if the SSL certificate is self signed (the default SSL Cert that was installed with the system)?
  8. integrity2
    Nov 10, 2009
    22
    Sorry, can you elaborate on what you mean by this:
  9. CvdPost
    Sep 28, 2013
    I am having the same issue with iPhone 5s (iOS 7) and latest 3CX System 12 software - not connecting, no presence etc, but show "On Hook" and calls can be made. Interestingly enough, an iPad with the same client (latest 3CX iOS client, iOS 7) configured the same, is NOT having the issue and connecting and showing presence (Windows clients are functioning correctly too). All devices are being used on a LAN.
    Can you please elaborate and explain where these settings need to be made. However in my case, I don't understand why one iOS device (iPad) is working and 2 iPhone 5s are not. Thanks.
  10. CvdPost
    Sep 28, 2013
    Got the iPhones working by editing the config file that is sent out with the email when creating a new extension (changing http to https etc etc). Still interested to know why the iPad worked without modification, yet the iPhones did not.
  11. Felixcat
    Sep 16, 2011
    12
    Hi CvdPost,
    I'm having the same problem too - would you be kind enough to tell me exactly which addresses you changed?
    Thanks in advance,
    Steve
  12. CvdPost
    Sep 28, 2013
    If I remember correctly I changed the "MyPhoneServerLocalAddr" and "MyPhoneServerLocalSSLAddr" to be https with a port of 5001 from http and 5000. Now I have Local and Public SSL and non-SSL all https and port 5001. Where x.x.x.x is the internal LAN IP address and y.y.y.y the External IP from the ISP.
    <ProvLink>https://x.x.x.x:5001/provisioning/fzv1o8akzs/TcxProvFiles/3cxProv_xxxxxxxxxx_123.xml</ProvLink>
    <MyPhoneServerLocalAddr>https://x.x.x.x:5001/MyPhone/MPWebService.asmx</MyPhoneServerLocalAddr>
    <MyPhoneServerPublicAddr>https://y.y.y.y:5001/MyPhone/MPWebService.asmx</MyPhoneServerPublicAddr>
    <MyPhoneServerLocalSSLAddr>https://x.x.x.x:5001/MyPhone/MPWebService.asmx</MyPhoneServerLocalSSLAddr>
    <MyPhoneServerPublicSSLAddr>https://y.y.y.y:5001/MyPhone/MPWebService.asmx</MyPhoneServerPublicSSLAddr>
    I am still experimenting so may be able to refine this, but it may be a start. I am not using name resolution but rather hard-coding in the IPs as I work through it. Compare the above to the standard file settings.
    Hope that helps.
    CvdPost
  13. Felixcat
    Sep 16, 2011
    12
    Hi CvdPost,
    Many thanks for your help - that has done the trick - all working now!
    Thanks again,
    Kind regards,
    Steve
  14. CvdPost
    Sep 28, 2013
    Glad I could help.
    I am sure I am going to need lots of help from others as I work through this great product - so please continue to post answers to our questions out there - or anything anyone learns that may be useful to others . I learn something everyday, it is an awesome product with fantastic features.
    CvdPost
  15. chlliew
    Mar 4, 2014
    8
    Can we setup the setting to automatic disable that https setting?
  16. alexdelyon
    Jul 2, 2010
    5
    I am having the same issue with iPhone 5s (iOS 7) and latest 3CX System 12 software.
    Where do we apply those changes ? we have to open and edit the config file that is sent out with the email ? If yes how do we open it ? it's a .3cxconfig !
    thank you !
  17. alexdelyon
    Jul 2, 2010
    5
    Nobody know how to do this ?
  18. alexdelyon
    Jul 2, 2010
    5
    Excuse me but is there somebody on this forum ???
    o_O
  19. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,128
    207
    alexdelyon,
    the config file is a simple text file that can be edited with notepad or other text edit program. do not use wordpad or word.
    but you should really try to find the root of the issue.
  20. alexdelyon
    Jul 2, 2010
    5
    Hello .
    My problem is solved !
    Yes the config file can be edited with notepad thank you !
    And my problem in the config file didn't came from the "https", i had just to change and put the good IP at the good place, and for this i just followed those explaination with x.x.x.x and y.y.y.y (I did not change the https from the original config file)
    Where x.x.x.x is the internal LAN IP address and y.y.y.y the External IP from the ISP :
    Thank's and good luck for all !
