Missing Caller Ext number in error mail message
Discussion in 'Ideas' started by orange2, Nov 4, 2015.
  1. orange2
    May 16, 2014
    5
    calling extension in trunk error emails please
    When a trunk error is generated, please can you add the extension that made the error call to the emailed report please
  2. Futureweb
    Futureweb New Member
    Jun 29, 2015
    163
    17
    V14SP2 - Trunk Error Mails
    When a Call failed due an Error from the Trunk an Email is sent to configured E-Mail Address ... would it be possible to add "From Number" / "Extension" to this E-Mail? So Admin can see who called the incorrect Number?
    Code:
    Call FROM EXTENSION or Registration to 000NUMBER000@(Ln.10000@xxxxx) has failed.
    Thx
    Andreas Schnederle-Wagner
  3. patrick.leemans@xs2t
    Jun 9, 2009
    5
    Missing Feature:
    Caller Extension number in 3CX error mail message:
    Date: 03/03/2016 09:53 (GMT+01:00)
    To: "Leemans, Patrick" <patrick.leemans@xxxxx.com>
    Subject: 3CX Phone System Email Notification - ID 12294 - Error response received from Trunk/Provider
    (0) XXXX3CX.xxx.agn 3/03/2016 9:52:21
    Event source: 3CXPhoneSystem
    Call or Registration to 0441215322309@(Ln.10005@xxxx SDSL) has failed. [ V4 xxxx:5060 UDP target domain=unspecified mFlowKey=964 ] replied: 404 Not Found; from IP:xxxx:5060
    When adding Caller extension number we can quickly identify and inform the caller (extension) who is dialing the wrong number.
    For example when Visitors are using our phone to make outbound calls they often dial a 0 in front which isn't needed in our PBX system.
    If we know in the mail from which extension this call is coming we can go to this person and tell him what he's doing wrong.
    Thanks,
    Patrick
  4. leejor
    11,291
    361
    You might want to consider reworking your outbound rules to prevent invalid numbers being sent to the provider in the first place. If certain incorrect number combinations are happening on a regular basis, you could create a dummy extension voicemail and route the calls there to inform them of their mistake, and how to correctly dial outside numbers.
    Outbound rules are read top to bottom, so more specific rules, that include the incorrect prefix would have to be above the more general rule.
  5. Futureweb
    Jun 29, 2015
    163
    17
    I already opened a Ticket for this some time ago ... you might want to upvote / comment it ...
    post177476.html#p177476
