Missing conference call dialog on Call Assistant
Discussion in '3CX Phone System - General' started by stuart.rendall, Sep 21, 2010.
  1. stuart.rendall
    May 26, 2010
    25
    If Call assistant is set to 'Always on top', and the conference call dialog is brought up, it disappears behind the call assistant and cant be used.
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Download the new call assistant that was released on the weekend.
    It remembers its placement. You can move it where you want and next time you start up it wont be in the way.
    I know it isnt a fix as such but it is a quick workaround that only needs to be done once.
