Missing first 5 seconds of audio
Discussion in '3CX Phone System - General' started by night1, Jan 4, 2018.
  1. night1
    Feb 12, 2013
    I'm having an issue with all inbound calls missing the first 3-5 seconds of audio BUT if you hang up and call right back the audio is not missing, if you wait about 3 minutes to call back the first 3-5 seconds of audio is missing again.
    Have checked with Vitelity and they do not see an issue
    tested this on a Windows and Linux deployment
    Firewall checker has no issues.
    Thoughts?
    Thanks,
  2. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    Make that two calls, with and without audio at the begining of the call, analyze both of them with wireshark and see is audio is really missing; what is happening after you provider sends ACK message to your PBX (you can see by time stamp in wireshark is there a problem with your provider, does audio coming right after ACK).
    If everything is OK try the same on the LAN interface.
    Also is there a missing audio in one way or two way?
  3. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    Looks like a network issue, check ping time, packet loss, jitter, latency.
    pathping <PBX_IP_address> is an useful command (Microsoft Command Prompt), run from a PC in the network with phones.
