Missing Phone Provisioning
Discussion in '3CX Phone System - General' started by RMI.ICT, Feb 12, 2016.
  1. RMI.ICT
    Sep 4, 2015
    Where did the setting Phone Provisioning go with v14?
    It seems to be missing after installing. See attached image.
  2. 12494
    12494 Member
    Apr 16, 2010
    292
    25
    Not clear what you are looking for.
    to set the provisioning template for a specific extension - edit the extension then go to the Provisioning tab.
    To activate provisioning - go to Phones node in mgmt console, highlight phone (or multiple phones) and click the Provision menu option.
    Allen
  3. RMI.ICT
    Sep 4, 2015
    Under Settings in 12.5 there was the menu Phone Provisioning containing the Provisioning URL, Time zone settings, Daylight saving time settings.
    I can't find the menu in 14 SP2. Did a complete reinstall and still the menu is gone. Where can I find it?
  4. 12494
    12494 Member
    Apr 16, 2010
    292
    25
    The phone provisioning url appears on the first screen in v14. I've had an issue where sometimes you had to zoom the browser display for it to appear. It will appear as the second line of item 5 - Configure and deploy,
    Allen
  5. RMI.ICT
    Sep 4, 2015
    Thanks. I found that one already after resizing the browser. In the manuals of 14 they still mention this menu item thats why I am asking if this has been removed or not.
  6. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,128
    210
    The screen is gone. Timezone is based on server.
    I liked the screen because by enabling DST (or vice versa) you could recreate all phone provisioning profiles quickly.
  7. RMI.ICT
    Sep 4, 2015
    Thanks for the info Craig!
  8. chris.moses
    Sep 13, 2015
    19
    Just a note that on our v14sp3 deployment, this did not work as expected. Our Yealink T4x phones were provisioned to pull the DST dates from the settings on the server. I don't think these are sent out anymore with v14. I had to manually edit the Yealink provisioning template and reset/reprovision the phones. I did confirm that the 3CX server was in the correct time zone and was displaying the correct time.
    #Configure the daylight saving time feature; 0-Disabled, 1-Enabled, 2-Automatic (default);
    local_time.summer_time = 2
    #Configure the DST type when the DST feature is enabled; 0-By Date (default), 1-By Week;
    local_time.dst_time_type = 1
    #Configure the start time of DST. The default value is 1/1/0.
    #If the DST type is configured as By Date, the value format is Month/Day/Hour. For example, the value 5/20/10 means the start time is at 10:00 on May 20.
    #If the DST type is configured as By Week, the value format is Month/Day of Week/Day of Week Last in Month/Hour of Day.
    #For example, the value 1/4/2/5 means the start time is at 5 o'clock on Tuesday of the 4th week in January.
    local_time.start_time =3/2/7/2
    #Configure the end time of DST. The default value is 12/31/23. The value format is the same to the start time.
    local_time.end_time =11/1/7/2
    #Configure the offset time (in seconds). It ranges from -300 to 300, the default value is 60.
    local_time.offset_time = 60
    #Configure the time format; 0-12 Hour, 1-24 Hour (default);
    local_time.time_format = 0
