Missing SN-4114 FXO Template
Discussion in '3CX Phone System - General' started by mcgee.will, Aug 13, 2013.
  1. mcgee.will
    Aug 13, 2013
    Ok I may be missing something but, I do not see the Patton 4114 FXO Template.
    I know in version 10 it was listed with a template, but I can't find that template in version 12? The only template I can find is the FXS version.
    I attached image of my version 10 server on left and version 12 server on right.
  2. CentrexJ
    CentrexJ Member
    May 5, 2009
    470
    77
    I just checked my v12 RC1 and you are correct mine wasn't there either when trying to add a new device. I then went to "3cx phone system updates" and "voip gateway template updates". It lists the "Patton SN-411x FXO's" and showed them as "up to date".
    I checked the box beside the two lines and choose "download selected".
    Now when I go to add a "Voip/PSTN Gateway" it shows the Patton SN-4114 FXO on the list.
    Hope that helps.
