Mobile Extensions Ringing on DND
Discussion in '3CX Phone System - General' started by thames, Nov 13, 2015.
  1. thames
    thames New Member
    Apr 4, 2011
    102
    Hi there Folks
    This may well be a daft question but it's driving me crazy so I wondered if there was an answer to this:
    I have several mobile extensions set up on our 3CX system. I have a group set up called "Mobile Group" so that when we are out of office and someone rings in, it'll use the PUSH to ring the mobiles. It works just fine. However, when we don't want to be disturbed and we switch the mobiles to DND - they still ring! It almost appears that 3CX is ignoring the extension setup and just looking at the ring group setup.
    Is there a way around this? Basically what we want is that when one or more of the mobile extensions are set to DND or Away, either the remaining ones only will ring or, if they are all set to DND, none of them will ring and the incoming call will go directly to voicemail.
    Cheers
    Chris
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,947
    179
    As far as I know DND does not affect a ring group. Perhaps there is an option or better yet use a queue.
  3. thames
    thames New Member
    Apr 4, 2011
    102
    Hi Craig
    OK - so as I guessed, the ring group settings are overriding the extension setup?
    Hmmm - so if I wanted to ensure that the mobiles didn't ring I could create a mobile queue - now that sounds like a great idea. I'll try that and post what I find.
    Cheers
    Chris
  4. thames
    thames New Member
    Apr 4, 2011
    102
    Hi Craig
    BINGO!
    I created a Call Queue for mobile extensions only. Created a personalised message so that incoming calls would know what was happening. When mobiles are logged into the queue they ring and when they aren't... well - it works just fine.
    Thanks for your response to the original question - much appreciated.
    Cheers
    Chris
  5. craigreilly
    Feb 1, 2012
    2,947
    179
    Sure thing. Glad that solution works for you.
