Mobile gateway
Discussion in '3CX Phone System - General' started by no1daag, Feb 8, 2007.
  1. no1daag
    Feb 8, 2007
    29
    I
  2. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    We have not tested with any GSM gateways, though your setup does sound very interesting!
    I am sorry I cannot give any insight, but if you do come across a solution we would love to hear from your experiences.
  3. fdk
    fdk
    Feb 20, 2007
    GSM Adapter ?
    __________________________
    Offer a~z traffic router support H323&Sip
  4. Anonymous
    Anonymous Guest
    Yep, that can work but not with GSM as you use thirdparty hardware. So this is how I resolved it. We had the same issue in the company, the result is that we use the estate where the office is as test bed.
    Yeah yeah "free" internet and VoIP phone for the whole estate I know I know :).
    Anyway we use WiFi, reason being is that we see that more and more devices use WiFi. We have HP6515 with Wifi cards. So GSM calls are routed via GSM, however when we are in our Bee Hive (coverage and overlapping coverage by WiFi using the available WiFi devices in the estate) we use the PDA's to call via VoIP.
    Now the trick is you can expand on this, everywhere you have a WiFi hot spot you can use your VoIP (taking VPN etc in account) You need some SIP software on the PDA but that is available on the internet.
    D-Link now comes out with WiFi phones and for sure there are more suppliers that will come up with WiFi GSM phones.
    The principle is old, the technoligy is new :)
  5. no1daag
    Feb 8, 2007
    29
    ITfarmer: Looking also for this solution but I have to upgrade my Nokia N80 to Nokia N80IE for this purpose, Nokia doesn
