Mobile operator's message not performed
Discussion in 'Windows' started by jvictormonteiro, May 7, 2015.
  1. jvictormonteiro
    May 7, 2015
    When I run the dial to a number that is off the message from the phone operator is not executed, only the "Not Available" message. I wonder if there is enabling all carrier return messages, rather than a sequence of false ring.
    My version of 3CX is 6.0
    Regards!
    11,127
    330
    Would you please provide clarification.
    I take it you are placing an outside call via a VoIP provider, where the called party is...??? I'm not certain what "Off" means. Do you mean a mobile that is off? What happens with calls to a landline?
    What audible message are you getting? A recording that says the party is not available?
    What type of set are you calling from?
    What VoIP provider are you using? Another Forum member may have experience with them.
