Mobile Phone Availability connector to 3CX
Discussion in '3CX Clients' started by Sorby, May 19, 2017.
  1. Sorby
    Jan 27, 2017
    19
    12
    "The Zello app sets your status to Busy when you're on a phone call(cellphone call). The status returns to Available after your call ends."
    It had been nice if the 3CX app could have done this. The switchboard
    still tries to transfer calls to me when I'm busy in a mobile call.
    jed likes this.
  2. jed
    jed New Member
    Feb 1, 2010
    145
    42
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,479
    67
    How a GSM call will launch the 3CX app? Most of the time, 3CX app is not running.
  4. jed
    jed New Member
    Feb 1, 2010
    145
    42
    Comeon Vali, you can do it;)
    Joking aside.
    Dont you have anything running on softphone/PUSH that can be used to sniff that a GSM Call is in use?
    The reason for my wish, is that we have lots of companies, interested in 3CX, but where it is a nogo to force them to use a softphone (however we can install a SoftPhone) and it is a nogo to change the tecco for these CellPhones.
    If we could offer Pressence nomatter if they is only using GSM for theiere CellPhone calls, then we will be able to sell to these - offen bigger - companies, and we will be able to sell a bigger 3CX (more Sim Calls).
    Hope you can see a solution, that can hanle pressence nomatter if they is using 3CX SoftPhone, or the GSM for theier in and outbound on the CellPhones..
    Thank you in advance
    /Jesper
  5. Vali_3CX
    Dec 12, 2008
    1,479
    67
    Hi Jesper
    Yes, when the 3CX client is running, we can detect a GSM call. The problem is when 3CX client is NOT running.
    Basically, what you ask for is to make the 3CX client a service monitoring GSM calls: it should not be terminated by the user, it should launch when device starts, it should have a continuous, stable connection with the MyPhone server.
  6. jed
    jed New Member
    Feb 1, 2010
    145
    42
    Hi Vali
    Yes if this is the solution, then yes...
    Can you also see the benefit og this?
    /Jesper
  7. Sorby
    Jan 27, 2017
    19
    12
    It would be great if the 3CX client could monitoring GSM calls and show "Busy" presence in the 3CX solution
    Solutions such as Innovaphone support this in their mobile App.
