Modifying Caller ID display
Discussion in '3CX Phone System - General' started by simonhc, Feb 3, 2017.
  1. simonhc
    Dec 9, 2011
    41
    I have just changed my VoIP provider from BT to OrbTalk and am having an issue with the caller ID display on the phones.
    I am currently using Cisco 509g's and prior to the change-over where display the ID perfectly. However OrbTalk broadcast all numbers in the international format. i.e. have the full international dialling code present.
    My office is in the UK and as a result nearly every call coming in starts with 44. however when it is a domestic call thee 44 should be replaced with 0.
    Is there a way to swap the 44 on incoming calls and replace it with 0
    so if an incoming call looks like 441234567890 i want to modify it to appear as 01234567890
    Thanks in advance
    Simon
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
  3. simonhc
    Dec 9, 2011
    41
    Thats great, thank you
  4. simonhc
    Dec 9, 2011
    41
    Do you know if this is possible on version 10 of 3cx?
    I have an old version running at home and would like to implement this at that end as well.
    Thanks in advance
    Simon
  5. eagle2
    Apr 27, 2011
    1,085
    11
    No, I think earliest version was 12 to support Caller-ID reformatting. In version 11 there was another method, no so convenient.
  6. simonhc
    Dec 9, 2011
    41
    Ok,
    Worth an ask.. Thanks for letting me know.
    Simon
  7. simonhc
    Dec 9, 2011
    41
    Just a thought but is there a way in version 10 to strip the first 2 digits from an outgoing number?
    Due to the above issue if I hit redial I currently get an invalid number error from OrbTalk (my VoIP provider)
    To clarify:
    - national calls in the UK all start with "0"
    - OrbTalk transmit all incoming numbers in the international format so UK would start with "44"
    - So a local number would look like: 01234567890
    - The international version of this number would be: 441234567890
    - When sending a number from 3cx to OrbTalk, OrbTalk require you to drop the "0" so that the number can be converted to the international format by simply add "44" to the start of the number.
    -So I have an outgoing rule in 3cx that strips the "0" from all outgoing calls. - simple.
    Unfortunately when an incoming call is received it is transmitted in the international format. The problem starts when I hit redial as I get an invalid number error due to OrbTalk adding the 44 to the start of the number;
    So the problem is this:-
    - I receive a call with the ID: 441234567890.
    - I hit redial and 3cx transmits the number to OrbTalk as: 441234567890
    - OrbTalk the add "44" to convert the number to the international format. Thus I am infact trying to dial: 44441234567890 which gives the invalid number error.
    So is it possible to check if the outgoing number starts with "44" and if so strip the first 2 digits from that number and transmit the remaining numbers? I.e.
    - I dial "441234567890"
    - 3CX stripps the "44" and transmits: "1234567890"
    I hope that makes sense.
    Thanks in advance
    Simon
