Module Intégration 3CX CRM with Asterisk
Discussion in '3CX Phone System - General' started by DStel, Oct 4, 2013.
  1. DStel
    Oct 4, 2013
    Hello everyone,
    I have a Ipbx Asterisk and have server SugarCRM, I wish the two coupled way to benefit from the popup automatic when a call arived on my softphone 3CX working with my ipbx Asterisk.
    I tried several plug'in of CRM without success.
    This is why I would guide me on the 3CX CRM Integration Module.
    But I do not know how to begin to test ...
    A priori it is necessary to install the 3CX PBX "3CX Phone System 10 or 12" but I have an Asterisk IPBX that I do not want to delete.
    So you it is possible to run the Module Intégration 3CX while keeping his Asterisk PBX?
    Thank you in advance for your help
  2. bardissi
    bardissi Member
    Jan 31, 2012
    318
    I believe the 3CX sugar crm plugin only works if you are using 3cx as your pbx
