MOH does not work
Discussion in '3CX Phone System - General' started by divyash, Jul 15, 2008.
  1. divyash
    Jan 27, 2008
    Hello Everyone,
    I recently upgrade my 3CX version to 6. Everything seems to be working fine except the MOH feature. I can put a caller on hold then resume the call, however, no MOH works. I have made sure that the checkbox in the General settings has been checked. I am using Polycom 501 and 601 phones.
    Any support is appreciated.
    Thank you,
    Divyash :roll:
  2. divyash
    Jan 27, 2008
    Thanks, I got it to work with the Ploycom's.
    Divyash
  3. amaze8
    Jul 21, 2008
    please do tell how you made it work!!!
    i have same problem with polycoms, however its a strange one.
    if i call another extension from one unit to another, MOH works
    if i put a pstn/voip input on hold, no MOH just silence.
    This is completely independent of polycom phones, it does the same with the software client.
    any tips?
    ant.
