MOH Not Playing
Discussion in '3CX Phone System - General' started by etj, May 24, 2010.
  1. etj
    etj
    May 21, 2010
    I have everyhting configured correctly. MOH is not playing when call is placed on HOLD. Any ideas?
    Regards,
    10,583
    251
    What operating system/hardware are you using? Can you play wave (or the hold music) file(s) through the sound card?
  3. etj
    etj
    May 21, 2010
    I am running it on SVR2008 Virtual Machine.
    Regards,
  4. leejor
    10,583
    251
    Did you see this post?
    http://www.3cx.com/forums/when-users-call-extension-they-dont-hear-ringing-or-music-13639-15.html#p74854
  5. redgoblet
    Jan 4, 2009
    35
    Have you enabled the Desktop Experience feature?
  6. etj
    etj
    May 21, 2010
    Ok, I enabled the Desktop Exp. I then restarted the VM. Now when I call into from an external number, my extension rings once on the handset in the cell I'm using for testing, it then goes to busy signal.
    Regards,
  7. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Please don't ignore http://www.3cx.com/forums/forum-rules-read-to-get-answers-93.html
