MOH quality
Discussion in '3CX Phone System - General' started by Janek, Oct 23, 2009.
  1. Janek
    Oct 6, 2009
    11
    I am finding MOH is quite poor quality
    I have replaced default with a royalty free file that sounds good when played back directly, but when used as MOH sounds very tinny & with clips & jumps. I've tried MP3 & Wav formats and they just sound the same.
    Can someone advise the best format to use or give suggestions to improve the quality
    I have 3CX v8.0.9532.468
  2. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Keep in mind it is translating it to the relatively poor audio quality of a telephone call. It's never going to sound as good as the original files when played with a media player.
  3. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    Create audio files in the format: WAV, PCM, 8 KHz, 16Kbps Bitrate are the recommendations by 3CX
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    You forgot to specify software/hardware environment...
    Do you have the same problems with default MOH?
