- Joined
- Oct 8, 2010
- Messages
- 1
- Reaction score
- 0
Salut!
J'ai comme un inconvénient avec mon 3CX, j'ai 5 passerrelle skype avec un Master.
Une extension (100) qui distribut les appels vers un répondeur numérique spécifiques. Si 2 personnes appellent en meme temps, il (l'extensions ou l'IVR) répond un et l'autre reste et sonne et sonne, jusqu'à ce qu'il rachroche. Mais avant de rachorcher il alerte l'autre appel ( To add this caller to current call press five to accept press one, to send to the voice mail press two) si tu fais rien il racroche.
21:37:57.105 [CM503008]: Call(55): Call is terminated
21:37:54.686 [CM503008]: Call(56): Call is terminated
21:37:41.420 Currently active calls - 2: [55,56]
21:37:39.076 [CM503007]: Call(56): Device joined: sip:[email protected]:40600;rinstance=b927a6d98726f7af
21:37:39.073 [CM503007]: Call(56): Device joined: sip:[email protected]:6062;rinstance=67a16a5b7ca13d64
21:37:39.064 [CM505001]: Ext.803: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX IVR;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] PBX contact: [sip:[email protected]:5060]
21:37:39.061 [CM503002]: Call(56): Alerting sip:[email protected]:40600;rinstance=b927a6d98726f7af
21:37:38.912 [CM503025]: Call(56): Calling Ext:Ext.803@[Dev:sip:[email protected]:40600;rinstance=b927a6d98726f7af]
21:37:38.872 [CM503004]: Call(56): Route 1: Ext:Ext.803@[Dev:sip:[email protected]:40600;rinstance=b927a6d98726f7af]
21:37:38.871 [CM503010]: Making route(s) to <sip:[email protected]:5060>
21:37:38.868 [CM505002]: Gateway:[Fred] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.9919.0] PBX contact: [sip:[email protected]:5060]
21:37:38.862 [CM503001]: Call(56): Incoming call from +17404229470@(Ln.10001@Fred) to <sip:[email protected]:5060>
21:37:38.857 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10001 forwards to DN:100
21:37:20.260 [CM503007]: Call(55): Device joined: sip:[email protected]:40600;rinstance=b927a6d98726f7af
21:37:20.255 [CM503007]: Call(55): Device joined: sip:[email protected]:6070;rinstance=b6e1435218c6631e
21:37:20.246 [CM505001]: Ext.803: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX IVR;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] PBX contact: [sip:[email protected]:5060]
21:37:20.245 [CM503002]: Call(55): Alerting sip:[email protected]:40600;rinstance=b927a6d98726f7af
21:37:20.103 [CM503025]: Call(55): Calling Ext:Ext.803@[Dev:sip:[email protected]:40600;rinstance=b927a6d98726f7af]
21:37:20.065 [CM503004]: Call(55): Route 1: Ext:Ext.803@[Dev:sip:[email protected]:40600;rinstance=b927a6d98726f7af]
21:37:20.064 [CM503010]: Making route(s) to <sip:[email protected]:5060>
21:37:20.062 [CM505002]: Gateway:[Virtuelle.plus.plus] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.9919.0] PBX contact: [sip:[email protected]:5060]
21:37:20.052 [CM503001]: Call(55): Incoming call from +17404229470@([email protected]) to <sip:[email protected]:5060>
21:37:20.046 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10002 forwards to DN:100
21:37:02.647 [CM503008]: Call(54): Call is terminated
21:36:59.045 [CM503008]: Call(53): Call is terminated
21:36:46.432 [CM503007]: Call(54): Device joined: sip:[email protected]:40600;rinstance=b927a6d98726f7af
21:36:46.430 [CM503007]: Call(54): Device joined: sip:[email protected]:6064;rinstance=0886e109b64cb381
21:36:46.422 [CM505001]: Ext.803: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX IVR;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] PBX contact: [sip:[email protected]:5060]
21:36:46.422 [CM503002]: Call(54): Alerting sip:[email protected]:40600;rinstance=b927a6d98726f7af
21:36:46.274 [CM503025]: Call(54): Calling Ext:Ext.803@[Dev:sip:[email protected]:40600;rinstance=b927a6d98726f7af]
21:36:46.234 [CM503004]: Call(54): Route 1: Ext:Ext.803@[Dev:sip:[email protected]:40600;rinstance=b927a6d98726f7af]
21:36:46.233 [CM503010]: Making route(s) to <sip:[email protected]:5060>
21:36:46.231 [CM505002]: Gateway:[virtuelle.fleur ] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.9919.0] PBX contact: [sip:[email protected]:5060]
21:36:46.224 [CM503001]: Call(54): Incoming call from +17404229470@([email protected] ) to <sip:[email protected]:5060>
21:36:46.219 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10003 forwards to DN:100
21:36:39.414 Currently active calls - 1: [53]
21:36:30.231 [CM503007]: Call(53): Device joined: sip:[email protected]:40600;rinstance=b927a6d98726f7af
21:36:30.228 [CM503007]: Call(53): Device joined: sip:[email protected]:6062;rinstance=67a16a5b7ca13d64
21:36:30.222 [CM505001]: Ext.803: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CX IVR;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CX IVR] PBX contact: [sip:[email protected]:5060]
21:36:30.221 [CM503002]: Call(53): Alerting sip:[email protected]:40600;rinstance=b927a6d98726f7af
21:36:30.073 [CM503025]: Call(53): Calling Ext:Ext.803@[Dev:sip:[email protected]:40600;rinstance=b927a6d98726f7af]
21:36:30.035 [CM503004]: Call(53): Route 1: Ext:Ext.803@[Dev:sip:[email protected]:40600;rinstance=b927a6d98726f7af]
21:36:30.034 [CM503010]: Making route(s) to <sip:[email protected]:5060>
21:36:30.031 [CM505002]: Gateway:[Fred] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXSkypeGateway 2.0.9919.0] PBX contact: [sip:[email protected]:5060]
21:36:30.025 [CM503001]: Call(53): Incoming call from +17404229470@(Ln.10001@Fred) to <sip:[email protected]:5060>
21:36:30.019 [CM503012]: Inbound out-of-office hours rule (unnamed) for 10001 forwards to DN:100
Comment faire pour qu'il transfere tout les appels sans posé de questions?
Merci d'avance...
Merci d'avance...
