Monitor status: OFFLINE
Discussion in '3CX Phone System - General' started by glynco, Jul 18, 2007.
  1. glynco
    Jul 14, 2007
    20
    Everyday my 3CX do not work so I need to reinstall 3CX everyday.
    The monitor status is OFFLINE.
    PBX and DR in server status are RED.
    Anyone know how to fix this so that I don't need to reinstall 3CX EVERYDAY?
  2. Anonymous
    Anonymous Guest
    For the L... O... G... i have no idea why you have to reinstall 3cx everyday.
    Have you tried simply restarting the box?
    What is in the error logs?
  3. glynco
    Jul 14, 2007
    20
    This is not about the LOG.
    This is about the 3CX software not working everytime I boot my computer. That is why I need to reinstall it inorder to work.
    No dialtone. Cannot make and receive calls.
    Server is OFFLINE and PBX is RED.
  4. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    What operating system is it using? Are you logging in to a domain? Do you get a message that Windows cannot find your profile and that it is using a temporary profile(if so, you have a network problem and all of your settings are being discarded each time you re-boot)?
    We need more info to be able to help you.
  5. glynco
    Jul 14, 2007
    20
    I do not have network problem. After I reinstall the 3CX everything goes well and I don't reboot it anymore because when I reboot 3CX won't run again.
  6. Anonymous
    Anonymous Guest
    does not stand for LOG, it is an expression we have here in AU. It is similar to :roll: and throwing the hands in the air.
    Can you post your log files?
    Something is fishy. I think it is an OS issue that is related to your profile config, it might be that installing the software is ok using your profile but that the services running on the box do not have the correct rights.
    Hence the dump of the service. But the log file can tell us more.
  7. glynco
    Jul 14, 2007
    20
    Will this cause any problem with 3CX?
    Two network cards
    Two internet gateway
  8. Anonymous
    Anonymous Guest
    Yep that will do it.
    Disable one network card and the world of wonders will present it self.
    Two network cards, in particular on the same network segment, causes troubles.
    You can use multiple network cards, but they have to be on different network segments, and even then it can be fiddly.
    I had succesfully 4 nics in my 3CX box, but it was also running ISA so ISA was doing the routing hence no problems.
    Two gateways, should not be an issue.
  9. glynco
    Jul 14, 2007
    20
    It is on two different network segment.
  10. Anonymous
    Anonymous Guest
    any software providing the route as in isolating the nics?
    if not you have to do a fair bit of fiddling, best is to disable one of the nics.
  11. glynco
    Jul 14, 2007
    20
    It is on two different hub/switch not interconnected to each other.
    Two routers.
  12. Anonymous
    Anonymous Guest
    Does not matter, the software binds to both nics as they are both seen as "localhost"
    YOu have to make changes to the apache back end to only listen to one NIC etc it is fiddly but it can be done.
  13. glynco
    Jul 14, 2007
    20
    I tried disabling the other NIC. But still the same problem. I have to reinstall 3CX to run.
  14. silentfun
    silentfun Member
    Dec 11, 2006
    364
    not a fix but a workaround is to restart the services for 3cx manual from the system management. and perhaps u use a script to do this after each startup ?
  15. glynco
    Jul 14, 2007
    20
    How can I make the script?
    Is there a way to re-start 3CX from the command line?
  16. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    I also had a simular problem involving the service not to be started afther a reboot.
    the problem is in the 3cx user not beeing published in active directory (if you have that running) I had the problem the user was deleted OR stripped from the run as service right. Wich he needs to run the 3cx software.
    Might be worth looking into if you have active directory installed. I had to manually add the user and give it permission to run as service. Since then all went smooth afther reboots.
