nobody
- Joined
- Aug 15, 2017
- Messages
- 500
- Reaction score
- 55
I guess, this feature which comes as standard with most classic pbx is not possible with the current version of the 3cx PBX?
I want (example) three button on the phone (yealink T58 or T46):
Button1: call divert to mobile
Button2: call divert to internal number
button3: call divert to another external number
If I push the button, it will be lit in red.
If I push another button, it will disable all other call diverts and will be lit red
If I push the currently lit button the call divert will be disabled
The best way I currently can do this is:
I create different call diverts depending on the status of a user
Button one: change status to available
Button two: change status to aaa
Button three: change status to bbb
Button four: change status to ccc
Problem: there is no visual indication what kind of call divert is currently set, there is even no way to get the status using a code, and, I need 4 instead of 3 keys.
I think this is the same problem as the night mode visual indication
https://www.3cx.com/community/posts/258160/
Or is there a solution (which does not involve using a computer or mobile phone) for this?
