Monitoring VOIP QoS
Discussion in '3CX Phone System - General' started by chrischevy, Sep 1, 2010.
  1. chrischevy
    Jun 7, 2010
    74
    Does anyone use a software to monitor RTP ? I'd like to monitor the QoS applied on RTP and also mesure jitter, latency, etc...
    Thank you
  2. RichardCrabb1
    RichardCrabb1 New Member
    Mar 7, 2009
    196
    I don't have software that will monitor in real time, but it is possible to do a speedtest to check the characteristics with VoIP. This is one that I have used: http://www.telappliant.com/speedtest The results are fairly comprehensive and I have found that they are a reasonable guide that can be trusted.
    Also, wireshark can be helpful in looking at jitter but does not give a complete analysis.
    Kind regards
    Richard Crabb
  3. dsnyc
    Aug 30, 2010
    34
    Wireshark is the industry standard professional tool.
    This is a new service that does hosted VOIP monitoring. Might be worth looking into (haven't use them myself):
    http://www.voipspear.com
  4. chrischevy
    Jun 7, 2010
    74
    Thank you for the replies.
    I know Wireshark, but I'd like to find a similar software that is more VOIP oriented.
    I might try CACE pilot (wireshark add-on) http://www.cacetech.com/products/cace_pilot.html
    It seems to include some VOIP tools.
  5. comresource
    comresource Member
    May 22, 2009
    303
    I have played with VQManger in the past. There is a free version as well.
    http://www.manageengine.com/products/vqmanager/index.html
