More fields (columns) and filtering in extensions view screen. More mass-editable fields.
Discussion in 'Ideas' started by the60, Jan 18, 2018.
More fields (columns) and filtering in extensions view screen. More mass-editable fields. 5 5 2votes
5/5, 2 votes
  1. the60
    the60 New Member
    Oct 21, 2011
    117
    55
    Please consider adding additional columns in the extensions view screen.
    • Group
    • Endpoint (phone) make & model
    • Template used
    • Queue(s) assigned
    • Voicimail (Y/N)
    • Current status (available, etc.)
    • Queue Status
    Please enable filtering by all columns, so, for example, we can view all extensions in a specific department, and/or other fields as well.
    This will enable easier mass-edits of logical groups of extensions.
    On the subject of mass-eds, please allow many more extension fields to be editable when selecting multiple extensions.
    Lastly, allow importing of existing extensions, where the import process allows edits, not just creation of new extensions. Perhaps add a field in the CSV? (N=new; U=Update, etc.)
    3CX is great, but manageability of extensions for very large systems is tedious.
    Thanks!
