More music on 3CX?
Discussion in '3CX Phone System - General' started by Jos44, May 4, 2016.
  1. Jos44
    May 3, 2016
    Hello
    I would like to know if 3CX could offer more .wav files? I know it is against the laws to download neccessary .wav files from Internet.
    When someone calls to me, (calling goes through Digital Receptionist and then ends on Call Que), then caller hears a little bit weird .wav file.. :D. I want so that caller hears normal ring tone when he dials to number...
    So where i could download some normal .wav files for 3CX ?
  2. jjwerkman
    Sep 25, 2012
    42
    I created my own tone. And added that one as music.
    You can have it here: https://goo.gl/ezmVr3 (wektoon.wav)
  3. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Dunno about other locations, but the last straight v14 install still came with the USProgresstone.wav file.. use that.
