More than 20 phones / Windows 7 Licensing
Discussion in '3CX Phone System - General' started by cv7713, Mar 12, 2012.
  1. cv7713
    Mar 12, 2012
    This is my first post. We are about to pull the trigger on 3cx but had 1 concern. Our plan was to install on a Windows 7 Professional PC. Per the EULA, Windows 7 is limited to 20 devices. Has anyone had success with hooking more than 20 phones to a Windows 7 machine or will we need to use a server level OS? I know we've had issues in the past with our Symantec manager and concurrent connections. We had to use Server 2003. Any help is much appreciated!
    Our plan:
    26 IP Phones (Polycom, Cisco, or SNOM)
    Windows 7 Pro Machine
    100% SIP
    -Chris
  2. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    Personally I would go to a server version. But I think it would work ok.
  3. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,939
    250
    These are IP devices that run Linux or some other firmware and so these have nothing to do with Microsoft. They are not even connecting to the Windows OS. You can use Windows 7 if you want...
  4. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Either would work fine but at the end of the day if I were you I'd go with whatever I was most comfortable with. With that being said to date we've only used XP, or Windows 7.
  5. ZenMasta
    ZenMasta New Member
    Mar 10, 2010
    174
    The connection limit applies to File and Printer sharing
  6. cv7713
    Mar 12, 2012
    I am posting the the response I received for those who are interested or have a similar question.
    The connection limitation applies to IIS (Windows Web Server). Since 3cx running on Windows 7 uses Abyss, the connection limitation is irrelevant. If you plan to use IIS on Windows 7, you will be limited to connecting 20 phones.
  7. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Windows licensing has nothing to do with 3CX and the number of phones you are using -- you may connect a thousand phones if you like. The same applies to IIS, etc.
    Regards
