More than 4 Calls
Discussion in '3CX Phone System - General' started by peterbunn, Jan 11, 2010.
  1. peterbunn
    Jun 3, 2009
    20
    If you had a mini licence, how would you know if you're trying to make more than 4 calls?
    10,368
    228
    You wouldn't be able to make the fifth call. I'm sure that there would be a log showing that the "maximum number of calls" had been reached as the reason. If you use the Demo code you are limited to two calls, try making a third and see what happens.
