More Than Just Prompts In 3CX Holiday Menu
Discussion in 'Ideas' started by kenttec, Jan 2, 2018.
More Than Just Prompts In 3CX Holiday Menu 5 5 5votes
5/5, 5 votes
  1. kenttec
    Jul 29, 2016
    64
    18
    Hi 3CX Chaps
    I have a suggestion for the box, every Christmas holiday I have to manually set and unset special holiday messages (Digital Receptionists) on customer's 3CX systems as they like to have a Christmas specific message different to their current out of hours message with the ability to leave a voicemail.
    I feel this will be an easy fix by giving you more options in the "Configure Holidays" menu, rather than just going to a prompt can we make it so it goes to IVR, extension or vmail. That way I can make the xmas holiday go to a Digital Receptionst solving my yearly headache.
    Many Thanks
    Kent Tec
  2. tvdir
    Feb 17, 2017
    66
    15
