more then one voicemail
Discussion in '3CX Phone System - General' started by Pete-TPP, Dec 13, 2007.
  1. Pete-TPP
    Dec 31, 2006
    24
    Is there a way to configure more than one voicemails? I have got different businesses running on one 3CX. Also different ones for opening and closing hours.
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    Only one greeting per ext.
    But why not set up several new "not in use" ext, and have different DR fallback to the right one?
  3. Pete-TPP
    Dec 31, 2006
    24
    ?? how
    How can I add more voicemails? I can only use ext. 999 as voicemail right?
  4. Mori
    Mori New Member
    Mar 23, 2007
    223
    yes, but 999 is ext to "special meny".
    From there you can enter any ext you like to check VM from..
    (You can check every VM from any phone)
  5. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    I think the answer you're both stumbling towards is that "no, 3CX doesn't natively support multiple voicemail mailboxes for a single user as yet, but if you can be bothered to create dummy users you can use their voicemail boxes for other purposes and access them separately when checking for voicemail".
    i.e. it's not a solution but a workaround (which doesn't leave you with a unified voice mailbox and hence is of little use)
  6. Pete-TPP
    Dec 31, 2006
    24
    I have tried and it works perfectly. Thanx you both.
  7. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I have a feature request for this if you care to add to it.
  8. Pete-TPP
    Dec 31, 2006
    24
    What do you mean?
  9. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Check in the "feature requests" forum - he has a thread in there.
  10. Mori
    Mori New Member
    Mar 23, 2007
    223
    This is description on forum "Future Requests"
    I guess what Rob means is that if he posts his idea here all we others have to support him for it to be popular.
    This way 3CX will consider implementing it.
    Am i right Rob? :wink: [/quote]
  11. Pete-TPP
    Dec 31, 2006
    24
    aha, now ic
  12. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Yes Mori, that is correct.
    The more requests voted for seems to make a difference with development. I might be wrong and they have a wonderful list of things to do but since they won't tell us we'll just keep posting away.
