More then one voip provider.. How to?
Discussion in '3CX Phone System - General' started by cwelle, Feb 23, 2010.
  1. cwelle
    Dec 16, 2009
    18
    Hi there..
    For now i use 2 voip providers.. One for incoming calls and one for outgoing calls.. For outgoing calls i use WEBCALLDIRECT, and it worx pretty well.. The problem is however that webcalldirect supports only one call @ the time, and i need more! So i tought of opening one more account with them or with lets say voipbuster, and use it parralel!
    How do i define that the 3cx should use webcalldirect account as a primary, but if the line is in use, it should route the call thru lets say Voipbuster account??
    Thnx in advance.. :)
  2. Erling Computer
    Feb 3, 2010
    7
    Create an outbound call rule.
    At the bottom of the page, you can prioritize up to three routes outgoing calls can take.
    Just make your two providers the first two choices.
