Move AWS 3CX server to new instance by making server image
Discussion in '3CX Phone System - General' started by William Hall, Apr 14, 2018.
  1. William Hall
    Apr 8, 2018
    19
    Can this be done?
    I have been trying out 3CX on an on-demand instance and I would now like to move it to a cheaper reserved instance.
  2. eddv123
    eddv123 Well-Known Member
    Aug 15, 2017
    1,577
    209
  3. William Hall
    Apr 8, 2018
    19
    I can just halt the old server and keep it in reserve.
    The new server will obviously have a new IP and MAC but everything on the disk will all be exactly the same
  4. William Hall
    Apr 8, 2018
    19
    In case anyone is interested this does not work because the IP address is changed.
    Also it is not necessary because one does not need to create a new instance for it to be reserved.
